Select Analyze > Fit Y by X.
Enter a continuous column for Y, Response.
Enter a nominal or ordinal column for X, Factor.
Figure 5.53 The Fit Y By X Launch Window
Note: You can also launch a oneway analysis from the JMP Starter window. Select View > JMP Starter > Basic > Oneway.
