Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Basic Analysis
Simulate
• Launch the Simulate Window
To launch the Simulate window, right-click on a column of calculated values in a report window and select Simulate. Simulate is available in many reports, including all reports that support bootstrapping. To use Simulate, the data table must contain a formula with a random component that simulates data.
Help created on 7/12/2018
