Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Life Distribution
• Life Distribution Report
Tip:
If you find that the report window is too long, select
Tabbed Report
from the red triangle menu.
If you have not selected a Failure Cause in the launch window, you will see the Life Distribution report. Use this report to analyze lifetime data where some time observations might be censored. The Life Distribution report contains the following content and options:
Event Plot
Compare Distributions
Life Distribution: Statistics
Life Distribution Report Options
Figure 2.6
Example of the Life Distribution Report for Fan.jmp
Help created on 7/12/2018
