Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Consumer Research
Choice Models
Choice Model Report
• Likelihood Ratio Tests
The Likelihood Ratio Test report appears by default if the model is fit in less than five seconds. If the report does not appear, you can select the Likelihood Ratio Tests option from the Choice Model red triangle menu. The report gives the following:
Source
Lists the effects in the model.
L-R ChiSquare
The value of the likelihood ratio ChiSquare statistic for a test of the corresponding effect.
DF
The degrees of freedom for the ChiSquare test.
Prob>ChiSq
The
p
-value for the ChiSquare test.
Bar Graph
Shows a bar chart of the L-R ChiSquare values.
Help created on 7/12/2018
