Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
MaxDiff Design
• MaxDiff Options
MaxDiff Options
Set Random Seed
Sets the random seed that JMP uses to control certain actions that have a random component. These actions include:
simulating responses using the Simulate Responses option
randomizing Run Order for design construction
selecting a starting design
To reproduce a MaxDiff design or simulated responses, enter the random seed and Number of Starts that generated them. Do this step before clicking Make Design.
Simulate Responses
Select this option to simulate response values. When you click Make Table, a Simulate Choice window opens along with the design table, and Probability and Choice Simulated columns are added to the design table. The Choice Simulated formula column contains random responses and the Probability formula column contains their probabilities.
To change the model used in simulating the responses, enter values in the Marginal Utility column in the Simulate Choice window for all factor levels but the last. Because the marginal utilities must sum to zero, you are not permitted to edit the Marginal Utility for the last level. Once you have specified the remaining Marginal Utility values, the last level of the factor is adjusted accordingly.
Number of Starts
The number of random starts used in constructing the design. This value is set to 10 by default.
Advanced Options
None applicable.
Help created on 7/12/2018
