Shows the T2 chart. Hotelling’s T2 chart is a multivariate extension of the X-bar chart that takes correlation into account.
Constructs multivariate control charts based on the principal components of Y. Specify the number of major principal components for T2. See T Square Partitioned.
Creates a new column in the data table. Stores a formula in the column that calculates the T2 values.
(Not available for sub-grouped data) Shows a Change Point Detection plot of test statistics by row number and indicates the row number where the change point appears. See Change Point Detection.
