You can save the distances to the data table by selecting the Save option from the Mahalanobis Distances red triangle menu.
Figure 2.8 Multivariate Robust Outliers Mahalanobis Distance Plot
Figure 2.8 shows the Mahalanobis distances of 16 different columns. The plot contains an upper control limit (UCL) of 4.82.This UCL is meant to be a helpful guide to show where potential outliers might be. However, you should use your own discretion to determine which values are outliers. For more details about this upper control limit (UCL), see Mason and Young (2002).
Help created on 7/12/2018
