Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Partition Models
Partition Platform Options
• Node Options
Node Options
This section describes the options on the red triangle menu for each node.
Split Best
Finds and executes the best split at or below this node.
Split Here
Splits at the selected node on the best column to split by.
Split Specific
Lets you specify where a split takes place. This is useful in showing what the criterion is as a function of the cut point, as well as in determining custom cut points. When specifying a splitting column, you can choose the following options for how the split is performed:
Optimal Value
Splits at the optimal value of the selected variable.
Specified Value
Enables you to specify the level where the split takes place.
Output Split Table
Produces a data table showing all possible splits and their associated split value.
Prune Below
Eliminates the splits below the selected node.
Prune Worst
Finds and removes the worst split below the selected node.
Select Rows
Selects the data table rows corresponding to this leaf. You can extend the selection by holding down the Shift key and choosing this command from another node.
Show Details
Produces a data table that shows the split criterion for a selected variable. The data table, composed of split intervals and their associated criterion values, has an attached script that produces a graph for the criterion.
Lock
Prevents a node or its subnodes from being chosen for a split. When checked, a lock icon appears in the node title.
Help created on 7/12/2018
