Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Normal Mixtures
Normal Mixtures NCluster=<k> Report
• Normal Mixtures NCluster=<k> Report
The Normal Mixtures NCluster=<k> report gives summary statistics for each cluster:
The Cluster Summary report gives the number of observations and proportion for each cluster.
The Cluster Means report gives means for the observations in each cluster for each variable.
The Cluster Standard Deviations report gives standard deviations for the observations in each cluster for each variable.
The -LogLikelihood table gives the negative loglikelihood, BIC, and AICc.
The Correlations for Normal Mixtures report gives the estimated correlation matrix for each cluster
Help created on 7/12/2018
