Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Prospective Sample Size and Power
• One Sample Standard Deviation Calculator
Use the One Sample Standard Deviation calculator to evaluate sample size for a hypothesis test about one standard deviation. Sample size and power are associated with the following hypothesis test:
versus the one-sided alternative:
where
σ
is the population standard deviation and
σ
0
is the hypothesized value. The difference to detect is the difference between
σ
and
σ
0
Help created on 7/12/2018
