Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Covering Arrays
Covering Array Window
• Output Options
Output Options
Make Table
Constructs the Covering Array data table.
Back
Takes you back to the Factors outline. You can make changes to the previous outlines and regenerate the design.
Note:
If you have defined Disallowed Combinations in the Restrict Factor Level Combinations outline, these are retained as a script. The script is shown in the Use Disallowed Combinations Script panel when you click Continue.
Help created on 7/12/2018
