Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Essential Graphing
Parallel Plots
• Parallel Plot Platform Options
The Parallel Plot red triangle menu provides the following options:
Show Reversing Checkboxes
Reverses the scale for one or more variables.
See
Local Data Filter
Redo Menus
, and
Save Script Menus
in the
Using JMP
book for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
For details about the context menu options that appear when you right-click on a parallel plot, see
Using JMP
Help created on 7/12/2018
