dt = Open( "$SAMPLE_DATA/Cities.jmp" );
dt << Process Capability(
Process Variables( :OZONE, :CO, :SO2, :NO ),
Spec Limits(
OZONE( LSL( 0.075 ), Target( 0.15 ), USL( 0.25 ) ),
CO( LSL( 5 ), Target( 7 ), USL( 12 ) ),
SO2( LSL( 0.01 ), Target( 0.04 ), USL( 0.09 ) ),
NO( LSL( 0.01 ), Target( 0.025 ), USL( 0.04 ) )
There is no extra syntax needed to differentiate between the two table types (wide and tall) when they are read using JSL. This example is based on the CitySpecLimits.jmp sample data table. It places the specification limits data table inside an Import Spec Limits() expression.
Spec Limits(
Import Spec Limits(
"$SAMPLE_DATA/CitySpecLimits.jmp"
