The Python interfaces are also scriptable using a Python connection object. A scriptable Python connection object can be obtained using the Python Connect() function. See Python Connect(<named_arguments>) in the JSL Syntax Reference.
Optional. Performs an Eval Insert() on the Python code before submission.
