Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
• Recurrence Analysis
Recurrence Analysis
Model the Frequency or Cost of Recurrent Events over Time
The Recurrence Analysis platform analyzes event times, where the events can recur several times for each unit, item, or person. In an industrial setting, these events can occur when a unit breaks down, is repaired, and then put back into service after the repair. The units are followed until they are ultimately taken out of service.
In a medical setting, recurrence analysis can be used to analyze data from continuing treatments of a long-term disease, such as the recurrence of tumors in patients receiving treatment for bladder cancer.
The goal of the analysis is to obtain the mean cumulative function (MCF), which shows the total cost per unit as a function of time. Cost can be a count of the number of repairs, or it can be the actual cost of repair.
Figure 5.1
Recurrence Analysis Example
Contents
Overview of the Recurrence Analysis Platform
Example of the Recurrence Analysis Platform
Launch the Recurrence Analysis Platform
Recurrence Analysis Platform Options
Fit Model
Additional Examples of the Recurrence Analysis Platform
Bladder Cancer Recurrences Example
Diesel Ship Engines Example
Help created on 7/12/2018
