Shows or hides calculations for comparing the fitted model to a simple mean model. See Analysis of Variance.
Shows or hides a report containing the parameter estimates and t tests for the hypothesis that each parameter is zero. See Parameter Estimates.
Shows or hides a report containing details, plots, and tests for individual effects. See Effect Details.
When the Effect Leverage Emphasis option is selected, each effect has its own report at the top of the Fit Least Squares report window. This report includes effect details options as well as a leverage plot. See Leverage Plots.
