As you modify items, you discard unsaved changes by clicking the Menu Editor’s Cancel button and clicking Yes to confirm. After saving customizations, you can also remove all customizations and revert to the original menus and toolbars.
Select View > Customize > Revert to Factory Defaults.
Click Yes to remove the current user’s customizations.
Select No to avoid adding those customizations to the current installation of JMP.
Select Yes to add those customizations to the current installation of JMP.
Note: Select Do not ask me again about merging my old menus for JMP to ignore customizations found in a previous JMP version every time you open JMP. However, when you revert toolbars and menus to the factory defaults, you always have the opportunity to merge old menus, whether you previously checked the merging old menus option.
Select View > Customize > Menus and Toolbars.
Click Change.
Click Revert All.
Click Yes to remove your customizations.
To restore the original properties of a built-in item, click Revert All, and then click Yes to confirm.
Click Save to save your changes.
