Figure 12.2 Reports Preferences
Prompt is selected by default.
Conditionally formats the color of the text that represents the values. Available for correlation values, p-values, and factor pattern values.
Conditional formatting is always applied to correlation values, p-values, and factor pattern values.
Conditional formatting is always applied to correlation values, p-values, and factor pattern values. However, the conditional formatting does not show when the report is printed.
Conditional formatting is never applied to correlation values, p-values, and factor pattern values.
Creates custom conditional formatting rules that can be applied to numeric columns or matrices. See Use Conditional Formatting in JMP Reports.
Note: Verify the Use an Asterisk with the PValue Format preference to ensure asterisk (*) is or is not used for any p-value conditions.
Select this option to display an asterisk (*) next to significant p-values. This option is on by default.
