Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
JSL Messages
Platforms
• Response Screening
Response Screening
obj<<Get PValues
Returns a reference to a PValues table.
obj<<Save PValues
Stores the
p
-values in an output data table.
obj<<Save Compare Means
Stores the means comparisons in an output data table.
obj<<Save Mean
Stores the means in an output data table.
obj<<Save Outlier Indicator
Saves Outlier Indicator for each fit.
obj<<Save Std Residuals
Saves the residual formula for each fit.
obj<<Select Columns
Select columns in the original table corresponding to selected rows in this table.
Help created on 7/12/2018
