For continuous Ys and categorical Xs, tests all pairwise comparisons across the levels of the categorical variable. For each comparison, the data table gives the usual t-test, a test of practical significance, an equivalence test, and a column that uses color coding to summarize the results. The data table also contains a script that plots Practical LogWorth by Relative Practical Difference. See Compare Means Data Table. For an example, see Example of Tests of Practical Significance and Equivalence.
See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information about the following options:
