Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Profilers
Contour Profiler
The Contour Profiler Report
• Response Settings and Controls
Response
The list of one or more responses, with a color legend. To change the color of a response, right-click the color legend for that response.
Contour
The current value of the contour on the contour profiler. Click in the box to change the value. The slider control can also be used to change the value of the contour.
Current Y
The predicted response based on the current X settings. The value is at the red line on the slider control. This value updates as the factor settings are changed.
Lo Limit
Enables you to set a lower limit for your response. Click in a box to set the limit or click the left triangle of the slider control for that response. If a response column’s Spec Limits column property has a value for Lower Spec Limit, that value is used as the initial value for
Lo Limit.
High Limit
Enables you to set an upper limit for your response. Click in a box to set the limit or click the right triangle of the slider control for that response. If a response column’s Spec Limits column property has a value for Upper Spec Limit, that value is used as the initial value for
Hi Limit.
When response limits are used, the profiler shows regions that are not feasible as shaded in the contour profiler plot.
Help created on 7/12/2018
