Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
JSL Messages
• SAS Integration Messages
Metadata Server Objects
metaserver<<Disconnect()
Function
Disconnects the metadata server.
Returns
Void.
metaserver<<Get Display Name()
Function
Gets the display name of the metadata server.
Returns
A string.
metaserver<<Get Host Name()
Function
Gets the host (machine) name of the metadata server.
Returns
A string.
metaserver<<Get Port()
Function
Gets the port used for the metadata server connection.
Returns
An integer.
metaserver<<Get User Identity()
Function
Gets the identify of the connected user as defined in metadata.
Returns
A string.
metaserver<<Get User Name()
Function
Gets the user name (login ID) that was used for the metadata server connection.
Returns
A string.
Help created on 7/12/2018
