Level <colname>
Midpoint <colname>
Ranked <colname>
RankAvgd <colname>
If a value is unique, then the averaged rank is the same as the rank. If a value occurs k times, the average rank is computed as the sum of the value’s ranks divided by k.
Prob <colname>
For N nonmissing scores, the probability score of a value is computed as the averaged rank of that value divided by N + 1. This column is similar to the empirical cumulative distribution function.
N-Quantile <colname>
Std <colname>
Help created on 7/12/2018
