The Self-Organizing Map (SOM) technique was developed by Teuvo Kohonen (1989, 1990) and extended by other neural network enthusiasts and statisticians. The original SOM was cast as a learning process, like the original neural net algorithms, but the version implemented here is a variation on k-means clustering. In the SOM literature, this variation is called a batch algorithm using a locally weighted linear smoother.
The goal of a SOM is not only to form clusters in a particular layout on a cluster grid, such that points in clusters that are near each other in the SOM grid are also near each other in multivariate space. In classical k-means clustering, the structure of the clusters is arbitrary, but in SOMs the clusters have a grid structure. The grid structure helps interpret the clusters in two dimensions: clusters that are close are more similar than distant clusters. See Description of SOM Algorithm.
