Suppose that you want to send a message to an object in the output. For example, in Fit Model, you want to send the Response Limits message to the Profiler object, Use the subscript operator ([ ]) to refer to the Profiler object.
fm = dt << Fit Model(
Y( :height ),
Effects( :age, :sex, :weight, :age * :weight, :sex * :weight ),
Personality( Standard Least Squares ),
Emphasis( Effect Screening ),
Run
obj = fm << Profiler(
1,
Confidence Intervals( 1 ),
Desirability Functions( 1 ),
Term Value( age( 12 ), sex( "F" ), weight( 105 ) )
Show( Profiler[1] << Get Desirability ); // show the limits before
Profiler[1] << (height << Response Limits(
{Lower( 50, 0.066 ), Middle( 58, 0.7 ), Upper( 70, 0.95 ), Goal( Minimize ),
Importance( 1 )}
Wait( 0.1 ); // for demonstration purposes
Show( Profiler[1] << Get Desirability ); // show the limits after
