By default, delta is set to 2. The default coefficient for each continuous effect is set to 1. An n-level categorical factor is represented by n–1 indicator variables. The default coefficients for the n–1 terms (which represent the categorical factor) are alternating values of 1 and -1. The default coefficients for an interaction effect with more than one degree of freedom are also alternating values of 1 and -1.
