Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Scripting Guide
Three-Dimensional Scenes
Setting the Viewing Space
• Setting up an Orthographic Scene
Orthographic scenes are specified in ways similar to perspective scenes. Issue the command
Ortho(
left
right
bottom
top
near
far
which specifies the four corners of the near plane, the distance to the near plane, and the distance to the far plane.
If you are dealing with a simple 2-D environment, you can set up a two-dimensional orthographic scene with the command
Ortho2D (
left
right
bottom
top
which specifies the corners of the two-dimensional view.
Help created on 7/12/2018
