If the file is in a directory that JMP represents as a path variable, such as the desktop or documents directory, the links contain the path variable, such as $DESKTOP/Corn Trials.jmp. See Path Variables in the Scripting Guide for more information.
Otherwise, the link contains an absolute path, such as C:/2017Data/Corn Trials.jmp.
Select File > Archive Project.
Click Save.
