The Even Order Effect Estimates report lists second-order effects that are identified as active. Active second-order effects are identified using the guided variable selection procedure described in Stage 2 Methodology. The block effect (if one is included) is also listed, whether it is significant or not.
Figure 7.9 Stage 2 Report
Parameter estimates for a regression fit of Y on the Stage 2 second-order effects defined by Y2nd. See Decomposition of Response.
The p-value computed using the t Ratio and the degrees of freedom for error (DF).
The square root of the mean square error that results from the Stage 2 analysis. RMSE is estimated as the residual variance from Y2nd after fitting the second order effects identified as active. See Decomposition of Response.
