Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Fitting Linear Models •
Generalized Regression Models
Statistical Details for the Generalized Regression Personality
• Statistical Details for Distributions
The distributions fit by the Generalized Regression personality are given below in terms of the parameters used in model fitting. Although it is not specifically stated as part of their descriptions, the Generalized Regression personality enables you to specify non-integer values for the discrete distributions.
Continuous Distributions
Normal Distribution
Cauchy Distribution
Exponential Distribution
Gamma Distribution
Weibull Distribution
LogNormal Distribution
Beta Distribution
Discrete Distributions
Binomial Distribution
Beta Binomial Distribution
Poisson Distribution
Negative Binomial Distribution
Zero-Inflated Distributions
Zero-Inflated Binomial Distribution
Zero-Inflated Beta Binomial Distribution
Zero-Inflated Poisson Distribution
Zero-Inflated Negative Binomial Distribution
Zero-Inflated Gamma Distribution
Help created on 7/12/2018
