The FDR PValue Plot is interpreted in the same way as for the platform itself. SeeThe Response Screening Report.
The FDR LogWorth by Rank Fraction plot shows FDR LogWorth values plotted against the ranks of the p-values. The plotted points decrease or remain constant as rank fraction increases. The plot gives an indication of what proportion of tests are significant. An example using the Response Screening personality is given in Response Screening Personality.
See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information about the following options:
