Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Reliability Growth
• The Reliability Growth Report
The Observed Data report appears by default. If the Parallel Systems data format is specified in the launch window, the Model Descriptions and Feasibilities report also appears by default.
The Model Description and Feasibilities report lists the name and descriptions of the parallel systems models. It also contains a column that shows if a model is available for the current data. If a model is listed as not available, the reason is reported in the right-most column of this table.
Help created on 7/12/2018
