Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Essential Graphing
Scatterplot Matrix
• The Scatterplot Matrix Window
The Scatterplot Matrix window shows an ordered grouping of bivariate graphs. In each graph, you can examine the relationships between each pair of variables.
Follow the instructions in
Example of a Scatterplot Matrix
to produce the plot shown in
Figure 11.6
Note:
For information about additional options, see
Scatterplot Matrix Platform Options
Figure 11.6
Example of a Scatterplot Matrix Window
Replace variables in the plot by dragging and dropping a variable, in one of two ways: swap existing variables by dragging and dropping a variable from one axis to the other axis; or, click on a variable in the Columns panel of the associated data table and drag it onto an axis. This feature is not available for matrices in the Square format.
Help created on 7/12/2018
