In Excel, select JMP > Preferences.
Figure 1.16 JMP Add In Preferences
Accept the default Data Table Name (File name_Worksheet name) or type a name.
Select to Use the first rows as column names if the first row in the worksheet contains column headers.
Select to Transfer Hidden Rows if the worksheet contains hidden rows to be included in the JMP data table.
6.
Select to Transfer Hidden Column if the worksheet contains hidden columns to be included in the JMP data table.
7.
Click OK to save your preferences.
Select JMP and then select the JMP destination:
