Change the colors representing the high, middle, and low values of the color column. This option is available only if you have specified a Coloring variable.
Shows or hides a legend that defines the coloring used on the treemap. This option is available only if you have specified a Coloring variable.
See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information about the following options:
