Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Basic Analysis
Contingency Analysis
• Two Sample Test for Proportions
Note:
See also
Example of a Two Sample Test for Proportions
When both the X and Y variables have two levels, you can request a confidence interval for a difference between two proportions. It also outputs the test corresponding to the confidence interval.
Description
Shows the test being performed.
Proportion Difference
Shows the difference in the proportions between the levels of the X variable.
Lower 95%
Shows the lower endpoint of the confidence interval for the difference. Based on the adjusted Wald confidence interval.
Upper 95%
Shows the upper endpoint of the confidence interval for the difference. Based on the adjusted Wald confidence interval.
Adjusted Wald Test
Shows two-tailed and one-tailed tests.
Prob
Shows the p-values for the tests.
Response <variable> category of interest
Select which response level to use in the test.
Help created on 7/12/2018
