Figure A.28 shows the Value Ordering panel for the Type column in the Car Physical Data.jmp sample data table. Reports that involve the values of Type place these levels in the order Sporty, Small, Compact, Medium, and Large. Use the buttons to the right of the Value Ordering list to specify your desired ordering for the values.
Figure A.28 Value Ordering Column Property for Type
Help created on 7/12/2018
