Suppose that your data consist of n rows and p columns. The rank of the covariance matrix is at most the smaller of n and p. In wide data sets, p is often much larger than n. In these cases, the inverse of the covariance matrix has at most n nonzero eigenvalues. Wide Linear methods use this fact, together with the singular value decomposition, to provide efficient calculations. See Calculating the SVD.
