This section describes the Y Options submenu. These commands apply to all Y variables, unless you have a legend level highlighted, then they apply to only the highlighted Y variable.
Replaces a bar chart with a line chart and connects each point with a straight line. Select the Show Points option to show or hide the points. Line Chart is also available as a platform option, which then applies to all charts at once.
Replaces each bar with a line drawn from the axis to the plotted value. Needle Chart is also available as a platform option, which then applies to all charts at once.
Assigns a color to statistics (y-axis) to identify them in overlaid charts.
Note: To see the impact of this change, you must turn on labels. From the red triangle menu, select Label Options > Show Labels.
