Using JMP > Import Your Data > Import Data Using the Excel Add-In > About the JMP Add-In for Excel
Publication date: 07/30/2020
The JMP add-in commands are in two groups:
Transfer to JMP
Preferences
Set preferences for transferring data from Excel to JMP.
Data Table
Transfer the selected data in your Excel file to a JMP data table.
Graph Builder
Transfer the selected data in your Excel file to a JMP data table and launch the Graph Builder platform.
Distribution
Transfer the selected data in your Excel file to a JMP data table and launch the Distribution platform.
Fit Y By X
Transfer the selected data in your Excel file to a JMP data table and launch the Fit Y by X platform.
Fit Model
Transfer the selected data in your Excel file to a JMP data table and launch the Fit Model platform.
Time Series
Transfer the selected data in your Excel file to a JMP data table and launch the Time Series platform.
Control Chart
Transfer the selected data in your Excel file to a JMP data table and launch the Control Chart platform.
Profile in JMP
Create/Edit Model
Set up preferences for using the JMP profiler with Excel data.
Run Model
Run the JMP profiler.
