Using JMP > Import Your Data > Import Data Using the Excel Add-In
Publication date: 07/30/2020
The add-in for Excel provides new capabilities to JMP and Excel users on Windows:
Transfer selected cells in Excel to JMP data tables. See Transfer Excel Data to a JMP Data Table.
Use the JMP Profiler with calculation models in Excel workbooks. The profiler tool is designed to bring the power of the JMP profiler to models residing in Excel worksheets. You do not have to recreate your Excel models in JMP, verify that they are correct, and maintain the model in both JMP and Excel. See Excel Profiler in Profilers.
Note: During the JMP installation, select the Excel Add-In. This installs the add-in for your version of Microsoft Excel.
Microsoft Excel 2010, Microsoft Excel 2013, and Microsoft Excel 2016 are supported.
