Using JMP > Save and Share Data > Create a Journal > Add and Edit Outlines
Publication date: 07/30/2020
You can group text and links in an outline and then click the gray disclosure icon to expand and collapse the group.
To add an outline, right-click in the journal, and then select Append Item > Add Outline Item. You can also add nested outline levels to outline levels that you have created. (When you click the red triangle menu of a graph that you have journaled, the Add Outline Item option is unavailable.) Click the outline’s red triangle and select Add Outline Item.
To edit the outline heading, double-click the heading, enter the new name, and press Enter.
To add text or links within an outline, click the outline’s red triangle and select an option described in Journal Right-Click Options. Note that these options are not available when you click a scripted item’s red triangle.
To add text or links outside an outline, right-click the journal and then select one of the options described in Journal Right-Click Options.
To edit a link, right-click the link, select Edit > Set Script, edit the path, and then click OK.
To edit the name of the link displayed in the journal, right-click the link, select Set Button Name, enter the new name, and then click OK.
Tip: On Windows, show the preceding options by holding down the Alt key and right-clicking the outline level’s gray disclosure icon.
