Using JMP > Save and Share Data
Publication date: 07/30/2020
Save and Share Data
Get Your Data Out of JMP
This chapter covers the following topics:
saving data tables as text files, SAS data sets, Excel files, and other formats
saving reports as interactive HTML and PowerPoint
emailing reports and data tables
saving analyses as scripts
saving parts of a report as a graphic
printing reports
copying and pasting reports
creating JMP journals or projects
saving JMP sessions
saving log windows
The method that you choose depends on how you want to interact with your analyses in the future:
If you want to interactively present your data, you might choose to create a JMP journal.
If you want to send data tables, linked reports, and other items to someone, you might choose to create a JMP project.
If you want to continue to explore a report later, you might choose to create a JMP report.
If you want to send a report to a non JMP user, you might convert the report to interactive HTML or a web report.
Contents
Save and Share Data Tables
Save as a Microsoft Excel File
Save as a CSV File on Windows
Save as a Text File
Save as a JSON File
Save as a SAS Transport File
Save as a Google Sheet
Deselect Display intranet sites in Compatibility View.Save as a SAS Data Set
Save Data Tables to a Database
Replace a Database with a Data Table
Save and Share Reports
Save a Report as Interactive HTML
Create a Web Report
Save as PDF
Save as PowerPoint
Setting the Graphic DPI
Save Your Analysis as a Script
Save Parts of a Report in a Graphic Format
Print Reports
Copy and Paste Reports
Create a Journal
Example of Making a Journal for a Presentation
Create a New Journal
Manage Links in Shared Journals
Add and Edit Outlines
Journal Right-Click Options
Control the Display of Outline Levels
Add a Graph or Graphic
Customize Journal Items
Prevent Modifications
Append Reports to a Journal
Save the Journal in Another Format
Delete Items from a Journal
Create a Project
Create a New Project
Save Files in a Project
Move Files to a Project
Share the Project
Projects Compatibility
Save JMP Sessions
Save Sessions upon Exiting
Save Sessions Manually
Save a Log Window
