Using JMP > Save and Share Data > Create a Journal > Append Reports to a Journal
Publication date: 07/30/2020
To append other reports to a report that you already journaled, open the journal and select Edit > Journal. If an area of an analysis window is selected, Edit > Journal saves only the selected area instead of the entire window.
Notes:
The journal window has the same functions as the report window: you can click icons, click and drag, and right-click to access menus.
When a report is journaled, the journaled copy is no longer connected to the data table. To maintain that connection, save the report as JMP report and insert a link to it in the journal.
