Publication date: 07/30/2020
Approximate F-Tests
To compute F-values and degrees of freedom, let p be the rank of . Let q be the rank of , where the L matrix identifies elements of associated with the effect being tested. Let v be the error degrees of freedom and s be the minimum of p and q. Also let and .
Table 5.3, gives the computation of each approximate F from the corresponding test statistic.
Table 5.3 Approximate F-statistics
Test
Approximate F
Numerator DF
Denominator DF
Wilks’ Lambda
Pillai’s Trace
Hotelling-Lawley Trace
Roy’s Max Root
