Design of Experiments Guide > Balanced Incomplete Block Designs > Balanced Incomplete Block Design Window
Publication date: 07/30/2020
The BIBD window updates as you work through the design steps. The outlines that appear, separated by buttons that update the outlines, follow the flow in Figure 24.5.
Figure 24.5 Balanced Incomplete Block Design Flow
The initial design window shows the Design Options outline.
