Using JMP > JMP Reports > Change the Appearance of Graphs
Publication date: 07/30/2020
There are many ways that you can format your report to meet your needs. The sections that follow detail how to make changes to the graphical portions of your output reports.
Tip: If you have a touchscreen, you can pan and zoom most graphs and axes in JMP. Graphs and axes change scale and zoom out if pinched, and zoom in if stretched.
Resize Graphs
Zoom In and Out
Change Line Widths
Change the Background Color in a Graph
Change the Color of Histogram Bars
Display Coordinates and Temporary Reference Lines
Scroll and Scale Axes
Customize Axes and Axis Labels in the Axis Settings Window
Customize Axes and Axis Labels Using the Pop-Up Menu
Change the Order of Values
Change the Pattern and Format of Selected Objects
Add a Graph to a Data Table
Customize Markers, Lines, Text, and More
