Using JMP > JMP Reports > Change the Appearance of Graphs > Change the Pattern and Format of Selected Objects
Publication date: 07/30/2020
Patterns appear on some objects such as bars and maps when you select them. You can change the pattern for a specific object in the legend.
Right-click the item in the legend and select Fill Pattern to select a new pattern.
To remove the pattern, right-click the item again and select Revert.
Modify the Format of Selected Objects in All Graphs
Select File > Preferences > Graphs (Windows) or JMP > Preferences > Graphs (macOS) to change the Filled Areas preferences.
To change the highlight on selected objects, select one of the following Filled Selection Mode preferences:
Selected Patterned
Striped pattern (the default setting)
Selected Darker
Solid darker color
Selected Outlined
Outline
Selected Same Color
The Fill Selection Color in the preferences formats the selected object.
To change the color of selected rows in graphic objects when the Fill Selection Mode is “Selected Same Color”, click the Fill Selection Color bar. The default color is red.
