Scripting Guide > Extending JMP > Communicate with SAS Cloud Analytic Services
Publication date: 07/30/2020
SAS Viya uses Cloud Analytic Services (CAS) code to perform calculations in the cloud. This feature provides a way for SAS Viya users and JMP users to collaborate. You can write CAS code in JMP to import data from and export data to the CAS server, convert CAS JSON text to a JMP data table, get a list of available CAS libraries, and more.
JMP 15 provides the first basic integration with CAS actions.
See the SAS CAS documentation at https://developer.sas.com/apis/cas/rest/current/apidoc.html for more information.
The SAS CAS documentation for CAS actions cover CASL, R, Python, Lua.
This section covers the following topics:
About CAS Actions
Connect to the CAS Server
Create and Submit a CAS Action
Create a New CAS Server
Import Data
View Datasets
Get a List of Available CAS Libraries
Export Data
Convert a CAS Table to a Data Table
Delete a CAS Table
Remove a CAS Table
Verify the Connection
Get Details about the Current Connection
Disconnect from the CAS Server
Terminate All Sessions
