Scripting Guide > Extending JMP
Publication date: 07/30/2020
Extending JMP
External Data Sources, Analytical Tools, and Automation
This chapter discusses scripting features that are particularly useful for production settings, such as the following:
a data feed for capturing real-time data from a laboratory instrument
using SAS, MATLAB, R, or Python through JMP Scripting Language (JSL)
using JMP with Microsoft Excel
connecting to databases
controlling JMP externally by OLE automation
parsing XML
publishing to JMP Public or JMP Live
communicating with REST web services
communicating with web APIs
Some general JSL commands that might be of particular interest for use in a production setting include Caption, Speak, Print, Write, and Mail. These commands are described in Functions that Communicate with Users in the Programming Methods section.
Contents
Real-Time Data Capture on Windows
Create a Data Feed Object
Read in Real-Time Data
Manage a Data Feed with Messages
Examples of Data Feed
Dynamic Link Libraries (DLLs)
Using Sockets in JSL
Socket-Related Commands
Messages for Sockets
Database Access
Run Query Builder Queries
Open Database Function
Creating a Database Connection and Executing SQL
Writing a SQL Query
Working with SAS
Make a SAS DATA Step
Create SAS DATA Step Code for Formula Columns
SAS Variable Names
Connect to a SAS Metadata Server
Get the Values of SAS Macro Variables
Preferences
Sample Scripts
Working with MATLAB
Installing MATLAB
Working with R
Installing R
JMP to R Interfaces
R JSL Scriptable Object Interfaces
Conversion Between JMP Data Types and R Data Types
Troubleshooting
Examples
Working with Python
Install Python
How JMP Finds Python on Windows
JMP-to-Python Interfaces
Equivalent Data Types for Python Send()
Equivalent Data Types for Python Get()
JMP Scoping Operators and Python
Python Name() and Python Send() Examples
Additional Python Integration Examples
Working with Microsoft Excel
Parsing XML
OLE Automation
Communicate with REST Web Services
Examples of HTTP Requests
OAuth 2.0 for Web APIs
Security
Using Postman for Redirect URLs
Authorization Code Grant
Implicit Grant
Resource Owner Grant
Using a Token
OAuth 2.0 Resources
Communicate with SAS Cloud Analytic Services
About CAS Actions
Connect to the CAS Server
Create and Submit a CAS Action
Create a New CAS Server
Import Data
View Datasets
Get a List of Available CAS Libraries
Export Data
Convert a CAS Table to a Data Table
Delete a CAS Table
Remove a CAS Table
Verify the Connection
Get Details about the Current Connection
Disconnect from the CAS Server
Terminate All Sessions
